I have all the same conditions:
Aerocool X1 with 158mm cooler height clearance
FX 6300
Biostar TA970 (which isn't a good oc-board)
I oc'd my cpu up to 4,1 ,the max temps stayed under prime95 under 45 celsius, but my board throttled due to too high temps on the north-bridge.
Although I set the fan to a more aggressive mode, it stayed relatively quiet at 1000 rpm.
Hope this is still helpful for you, if you haven't found another solution ;)
https://linustechtips.com/topic/344162-good-cooler-for-fx6300/
