Eh!
I am going to be custom water cooling my PC and have two questions:
1. I am not wanting to have hard piping bents(I know it's popular)or flex tubing but I want to do it with fittings for every angle. What is this style called and what tubing/fittings should i choose?
2. I have RGB LED's and an trying to keep everything white so I can choose my colour. Which liquid should I choose. Note: fave colour is around 400nm to 450nm but i do want it to look good across the spectrum.
At this point I am only going to cool my graphics card and processor because i have not found a water block for the vrm on my z97-pro (wifi)  motherboard yet but this may happen eventually.
Note: my case is the corsaire 700t so that is the space i am working with.
Thank you all in advance!!
God Bless!
Travis
https://linustechtips.com/topic/343698-custom-water-cooling-question/
So non bent hard tubing? That will be expensive as hell with fittings. There is no real name for it. You need to the same supplies for hard piping besides the heat gun and stuff. Fittings depend on the piping diameter and bitspower are usually known as the best.
AS for lighting, I'm not quite sure what your question is but mayhems makes nice coolant.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
Do you really have $1000-$1500 for a custom loop like that?
if you do, check out singularitycomputers on youtube, almost all of his builds are hard-pipe tubing with fittings, not bends, exactly like you want to do
