Just wondering if I get corsair 200r mid tower casing will the GTX 970 fit in it?
GTX 970 http://au.pcpartpicker.com/part/gigabyte-video-card-gvn970wf3oc4gd
Corsair 200r http://au.pcpartpicker.com/part/corsair-case-200r
Like what the others said, you'll probably have to get rid of that cage. Alternatively, you can get a mini-itx 970 and it should fit.
 junker build in the making
https://linustechtips.com/topic/343611-will-it-fit/#findComment-4680806
That's what she said ;)
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/343611-will-it-fit/#findComment-4680815
Try putting the tip in first and see how it feels :D
"Graphics and gameplay are not mutually exclusive."
"Nvidia, AMD, Intel, or whatever company out there has only one end goal and that is PROFIT.
If you think these companies exist for any other reason you're gonna be disappointed my dear. CAVEAT EMPTOR"
https://linustechtips.com/topic/343611-will-it-fit/#findComment-4680898
My joke +  you're advice + your location
is just so wrong on so many levels :D hahahahahaha
https://linustechtips.com/topic/343611-will-it-fit/#findComment-4680922
Well what's a good case that has a smilair price to corsair 200r that will fit the GTX 970 and does the corsair 200r even have a middle drive cage? I looked at the image of it it doesn't look like it has a middle drive cage so why wouldn't it fit?
There are motherboards that can allow graphics cards to be inserted lower.
Although a 970 would have no issue fitting in the 200R, I'd suggest going with the better N600: http://au.pcpartpicker.com/part/cooler-master-case-nse600kwn1
You need to quote a post or tag a member or else they won't get a notification you replied to them.
yup you have to remove a drive cage though
Yes.
EDIT: You may have to remove the drive cages if the PCpartpicker specs are correct.
There isn't a removable drive cage.
https://linustechtips.com/topic/343611-will-it-fit/#findComment-4682171
Maximum GPU Length
420mm
well lets hope this is true
https://linustechtips.com/topic/343611-will-it-fit/#findComment-4682176
ever heard of a drill and a drill bit?  B)
https://linustechtips.com/topic/343611-will-it-fit/#findComment-4682210
Well if i were to have asus pro gamer motherboard with gtx970 will it fit on corsair 200r? Without taking off the drive cage
Yes, it would.
So if I were to get asus h97 pro gamer with GTX 970 fit without removing the drive cage?
No need to make a duplicate post.
https://linustechtips.com/topic/343611-will-it-fit/#findComment-4686136
