Can't do other things while downloading. Need help!
I got upgraded my router and internet speed from 30 mbps to 60 and ever since then I have been having issues while downloading and also trying to play games or watch videos at the same time. My internet just gets super slow while doing everything else, the download stays fine but I cant do anythign else. Before I upgraded I could do other things as I was downloading. Can anyone help me out and give me some advice. Im using a Netgear Nighthawk router currently. My setup is Wall-Modem-Router-Computer.
@Battleship Yellow If you read the post it says what router he is using.
it sounds like the download is taking all the bandwidth and not allowing it to allocate some to other web activities.
check if the router has any firmware updates.
Main rig: i7 4790k, Cooler H55, EVGA GTX 980, Corsair Obsidian 250D, ASRock H97M-ITX/ac, G.Skill 8GB, 500GB 840 EVO, 1TB WD Black
Server:  HP DL380 G5 8x 300GB 10k Sata drives, 2x e5460 32GB Ram
NAS: Synology DS213 with 2 2TB WD Red Drives
depend on what you are downloading. You can try to find a download manager that allows your to limit download speed. (e.g. Steam has this option).
Side note: this won't help if you are torrenting, which takes too much upload bandwidth
