First PC build
I would suggest not going with a 4790K. A 4790 would save you the money because you will need at least 8GB of ram.
People say 16GB is ideal for content creation but you can get away with 8GB first.
Xeon for the price of an i5, near the same speed and with HT... best of all worlds.. Also it's locked so can't oc, just get a reasonable board to go with it.
So from what i've learned in this ttopic, is that amd isn't close to as good as Intel..
This is why you go intel:
This would be my pick.. So much more bang for your buck than the rest (apart from maybe the GPU, not looked at all the other builds)
Slightly (very slightly) slower cpu that the one you marked but stay away from Kingston V300.. It's a bait and switch (They changed the specs and components).. Intel 730 is a damn good drive and your getting 240GB vs 120. Worth it for the slight drop in cpu
