Hey guys, I have a cooler master hyper 212 and I was wondering if I would see any thermal benefit by putting a second fan on the opposite side of the heatsink in the pull direction. I have an extra case fan I'm not using. It's an airflow fan, but I'm not sure if I really need a static pressure one if it's going to be pulling. Anyway, thanks for the help!
https://linustechtips.com/topic/341824-hyper-212-evo-fan/
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/341824-hyper-212-evo-fan/#findComment-4657277
Would I see more of a benefit by putting in another intake at the top then? I have the corsair carbide 200r and there's a hard drive bay right in front of the other fan slot in the front.
It would help to list your specs.
https://linustechtips.com/topic/341824-hyper-212-evo-fan/#findComment-4657314
you may, honestly testing is the best way to see, sorry. i would add to intake or exhaust try both if you can. did you already pick up a fan? are you unhappy with your current temps or noise? how is dust?
https://linustechtips.com/topic/341824-hyper-212-evo-fan/#findComment-4657315
Is there room on the bottom for the fan?
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/341824-hyper-212-evo-fan/#findComment-4657321
Yes there's room at the bottom, but my case doesn't have very big legs so there's not a whole lot of room under there.
Yeah I really just have to test it. I've been trying to overclock and basically the socket of my motherboard gets very hot when stress testing. I have an 8320 with a had 970 board and I recently picked up a 990fx board (haven't installed it yet). I'm thinking this might help that socket temp a little. Core temps are just fine though and as far as I've seen, dust isn't an issue.
https://linustechtips.com/topic/341824-hyper-212-evo-fan/#findComment-4657331
i think general airflow would be better, use whatever filtered spots for intakes or make some. Been awhile for amd for me so i'm not the most knowledgeable but, you do need a beefy vrm and they can get hot. Glhf
https://linustechtips.com/topic/341824-hyper-212-evo-fan/#findComment-4657379
i think general airflow would be better, use whatever filtered spots for intakes for make some. Been awhile for amd for me so i'm not the most knowledgeable but, you do need a beefy vrm and they can get hot. Glhf
Ok well thanks man, I appreciate your help!
https://linustechtips.com/topic/341824-hyper-212-evo-fan/#findComment-4657385
Just make sure that you have the ability to match the speeds of the two fans, sounds silly but a friend of mine had the first fan on 100% all the time and the second fan auto controlled which would have done bad things for his air flow.
Definitely not optimal!
https://linustechtips.com/topic/341824-hyper-212-evo-fan/#findComment-4663367
