I'm want to build a pc for $1500 CDN.
Needs to do ULTRA 1080p gaming
Dual boot linux and windows
thats it
http://www.ebay.com/itm/CrossOver-27QD-P-SE-Pivot-2560x1440-LG-AH-IPS-Non-Glare-27-Monitor-/321647504430
this is the 1440p display im getting and i'll need 2 1080's on the side preferably UHD Ultrawide but this if possible?
Looking to get a mechanical keyboard
Cheapest gaming mouse
and i need the OS
Am I dreaming if so let me know ill take out the monitor.I really want a 1440p monitor though
https://linustechtips.com/topic/341809-first-time-builder-needs-help/
thats it
and i need the OS
tbh you're not gonna get much computer with all those extra expenses
thats it
and i need the OS
So this is the build you're saying you want. Yet as you can see by the price it is out of your budget, by far. Plus idk if this is what you're thinking but if you want to put games over all 3 monitors you're gonna get some terrible FPS with the 970.
But if you can drop all the monitors and go with a single 1080 24" then things will start getting better.
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($152.06 @ Amazon Canada)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($83.98 @ Newegg Canada)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($135.95 @ Vuugo)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($413.95 @ Vuugo)
Case: Corsair 200R ATX Mid Tower Case  ($69.95 @ Vuugo)
Monitor: Acer G247HL 60Hz 24.0" Monitor  ($137.86 @ DirectCanada)
Keyboard: Ducky Shine 4 Wired Gaming Keyboard  ($159.99 @ NCIX)
Mouse: Cooler Master Recon Wired Optical Mouse  ($43.00 @ Vuugo)
Other: 1440p monitor ($330.00)
Total: $2138.54
Generated by PCPartPicker 2015-04-05 02:03 EDT-0400
http://ca.pcpartpicker.com/p/pwRWCJ
Should I go for this or
A triple monitor 1080 setup
if i where u i would take that Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  and switch it out for
EVGA GeForce GTX 970 Super Clocked ACX 2.0 4GB GDDR5 Graphics Card price: $337.3
i would go for this because u can run 3 monitors one in hdmi and 2 in dvi all 3 with one additional port if monitor supports it, this all runs in 4k for $337.3
and if u are wanting gaming monitor with a 1 millisecond response time i would go with benq monitors GW2760HS but if this is just for video editing and or photo editing i would go with Samsung curve monitors  27” Curved FHD Monitor with a metallic stand
