Best affordable quiet 120mm airflow case fans
JetPowerss
I'm looking into getting some airflow fans for my case, the NZXT S340 to improve the temperatures of my system as well as decrease the noise of my system. I'm planning on a getting a fan controller for my rig too. I've got my eyes on the NZXT Grid+ as I've started using the CAM software from NZXT and this fan controller would fit in my case (as it doesn't have any 5.25" bays). Any recommendations on airflow fans? Quick side note, I'm going to get 2 EK Vardar fans for my CPU Cooler, the Cooler Master Hyper 212 Evo as they are extremely queit, high amout of static pressure and look good. They will be in a push/pull configuration.
Project: Veronica
  • CPU                  Intel Core i5 4690K @ 4GHz
  • Motherboard   ASUS Z97 Pro Gamer
  • RAM                 Crucial Ballistix Elite 16GB (4x4GB) 1866MHz
  • GPU                 NVIDIA GeForce GTX 1070 Founders Edition
  • Case                NZXT S340 Red/Black Edition
  • Boot                Samsung 850 Evo 256GB
  • Storage           2 x 1TB Western Digital Blue Hard Drives
  • PSU                 Corsair CX600M 80 PLUS Bronze
Be quiet have some awesome fans. I just get lots cheaper fans and run them low rpm. 2-3 decent fans are all you'll need. 2 fans on a 212 will lower temps by 2c or so, thee stock fan is kinda loud.
thanks. I'll only pick up one Vardar then. I'll have a look into the bequiet fans thanks!
Project: Veronica
