Graphics Card Upgrade Help!
Go to solution Solved by DavePwns,
@Searinex I think the FX 8320 the 960 2GB might be my best bet considering I only have about $350 saved up and desperately needing an upgrade
I need some serious help, I am new to pc gaming and I have owned this pc
my current specs
  •  System: AMD FX 4130 3.80GHz Quad-Core | AMD 760G Chipset | 8GB DDR3 |
  • Graphics: Radeon HD 6670 1GB Video Card
  • PSU: IP-S450CQ2-0 450W  PSU
as you can tell I am in desperate need of a new graphics card. My goal is to play far cry 4 on high/ultra 1080p at an average frame rate of at least 50. I would love to get the gtx970 but there are two things that are hindering me.
1. I'd have to get a new power supply unit
2. I don't know if my  CPU would be bottle necking this high end GPU
But if I get the GTX 960, I am curious if that will even be able to play games like far cry 4 on ultra at 50 FPS due to the fact that it only has 2GB of VRAM. OR should I just wait for AMD to release there cards in June?
I Guess my MAIN question is whether or not my CPU will negate the performance increase of the 970 compared to using a 960.
https://linustechtips.com/topic/341113-graphics-card-upgrade-help/
Oh yeah bottleneck i think.
But hey until you get your money to upgrade your mobo and cpu, you can play Far Cry 4
I can play FC4 in High 1080p on my 7790 Clocked at 1100Mhz
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
You live near a Micro Center?
The Rig: NZXT H440 M3 (Green and Black) (Ncase M1 coming soon!!) | Intel Core i5-4690k x BeQuiet PureRock Slim | EVGA GTX 1060 6GB SSC  | ASUS H81i Plus | 12GB EVGA SSC @ 1600MHz | Seagate Barracuda 2TB | Sandisk Ultra II 480GB | Corsair SF 450| LG 29" Ultrawide | CoolerMaster Quickfire Rapid TKL | Corsair M65 Black Sennheiser HD 558 (MOD) | Audio-Technica ATR 2500
I think you are in for an overall new computer, or atleast massive upgrading.
I would probably look for an average cpu motherboard and gpu, it would be around the same price as a new 970
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($104.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 270X 2GB Dual-X Video Card  ($169.98 @ OutletPC)
Total: $318.92
Generated by PCPartPicker 2015-04-03 23:42 EDT-0400
and will for sure help your computer out versus just a 970.
 i have 0 idea if those 450 watts you have is completely reputable or not, but if it is you are fine.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
New gen AMD's will most likely follow the rx-xxx road.. ie, introduce about 2 new top end cards and then re-badge the rest (like a 280x is a 7970) so there is little point waiting for those
Grab a new PSU, don't have to go mad but a good quality 450W will drive a 970 (or basically any other single gpu card), I'd still advise going 550W for a little more head-room..
Then I'd say grab a used 7970 or similar.. you'll be happy enough till you can / need to upgrade the CPU/mobo, which you can carry these across to.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
Total: $318.92
Haswell Refresh Incompatibility detected. When using h81 mobos, remember to NOT pick any CPU on this list.
In other words, change CPU to the i3-4130
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
You should upgrade the CPU first, I'd recommend FX 8350 unless you don't mind switching to Intel which of course needs the motherboard replaced as well. Then upgrade the GPU, go with R9 280X (unless you have bigger budget go further like 290/290X).
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
I don't have the money to upgrade my mobo AND a cpu, is the fx 8350 the best for an AM3+ slot?
You could use a FX 6300 or FX 8320 CPU and go with a GTX 960 2GB (Ti is not worth it since the GPU can't handle 4GB of textures).
Also the FX-9590 is the best AM3+ CPU, but it's $300.00.
