I have a project that I will soon be building that is seriously space constricted. Can anyone provide any information on using this type of riser? Or can anyone offer a better alternative. The object is to get the GPU to lay flat instead of directly on top of the motherboard.
https://linustechtips.com/topic/341101-pci-e-extension-riser-cable/
There are right angle adapters, but I recommend a flexible cable. There's really no performance impact, but be aware, if you get a cheap and improperly shielded one, it can cause some issues, and you needa  really good shielding to do crossfire /sli.
1275745750405_hz-cnmyalibaba-web1_20686.
http://www.amazon.com/PCI-E-Express-Extender-Flexible-Extension/dp/B008BZBFTG
I myself don't use them, but this should work.
