Radeon Graphics Card DONE? HELLPPP
Solved by Dannykins,
ya tried that... all drivers are good i guess.... might have to start looking for a new card...
as a last resort i would suggest removing the card and then reinstalling it, making sure everything is connected correctly before getting a new card, if however you have fried it, with the next card you get do not Over clock so high, it is better to increase slowly and benchmark each time its time consuming but better than replacing a card, do not feel so bad we all make mistakes and we learn from them, this is something that you will learn from think positive always ![]()
