hey guys so i have a project i just recently bought a used computer for cheap and want to give it some gaming power
The Pc:
Hp z200 workstation
Intel Core processor i3-550, 3.20 GHz, 73W, 4 MB cache, 1333 MHz memory, Dual-Core, HT
4 gigs ram
1 PCI Express Gen1 slot
x1 mechanical/x1 electrical
1 PCI Express Gen2 slots x16 mechanical/ x16 electrical (used for discrete graphics)
1 PCI Express Gen1 slot x4 mechanical/x1 electrical
1 PCI Express Gen1 slot x16 mechanical/x4 electrical
3 PCI slots (full-height, full-length)
1tb HD
https://linustechtips.com/topic/341086-need-to-upgrade-help-out/
And your question is?
Start by replacing the PSU then add in a card for your budget.. if budget isn't a concern, throw it away and start again (Not really but it's not great)
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/341086-need-to-upgrade-help-out/#findComment-4648928
