USB - Turn power off while PC is off.
By
Senzelian
in Peripherals
in Peripherals
Solved by Senzelian,
It should be in the Bios power menu.
So, I wanted to quicky inform you.
It did work. I went into the bios into the advanced mode.
From there on to the ARP options.
Then I enabled ERP (S4 and S5 whatever that means) and restarted my PC.
Now, when I turn my system off, the LEDs also turn off after a few seconds.
Thanks for your help
Featured Topics
saltycaramel ·
Posted in Tech News0 -
2
VinSen ·
Posted in New Builds and Planning2 -
1
Fahizzle ·
7
INotPablo ·
Posted in CPUs, Motherboards, and Memory1
