I was thinking of building a small movable PC for my older sister. I haven't chose any parts yet but do you guys know of any cases with handles and that are small, but have enough room for a normal sized graphics card. I might get a graphics card later on down the road for her to play games decently, but I don't really have any intentions of buying a very small form factor card.
Overkill Chill:
CPU: Intel® Core™ i5-3450 CPU with Hyper 212evo | RAM:  2 x 4 GB DDR3 MoBo: ASRock H61M-DGS R2.0 | PSU: Rosewill PHOTON 750W | GPU: SAPPHIRE DUAL-X R9 280 3GB | Case: Antec One Gaming | Storage: Kingston HyperX 120gb, Seagate 2 TB | OS: Windows 10 | Displays:  Asus VS228H-P, Hp 2009m
https://linustechtips.com/topic/340067-small-case-for-a-lan-rig/
depends, do you want micro atx ? mini ITX ? or full ATX ?
if you want an ATX build, the coolermaster storm scout 2 is really great. very nice transporting handle on the top made with metal and rubber.  great lan case
here is linus holding it upside down
http://i.ytimg.com/vi/TqNN2fHPK_M/maxresdefault.jpg
maybe you can try and find an old NZXT Vulcan case.. they are really good  (but discontinued.. thats why it has to be used...)
https://linustechtips.com/topic/340067-small-case-for-a-lan-rig/#findComment-4636241
i would also recommend the cm storm scout 2 bcs the handle pretty tough
-MnManX
https://linustechtips.com/topic/340067-small-case-for-a-lan-rig/#findComment-4636280
