i3 wins all CPU listed
your games will thank you for picking the i3 which has 4 treads
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4634824
Welcome to the forum! :) Be sure to follow your own posts, top right! @Gooplez
I'd personally get either the i3 or the FX-6300. 2 cores is simply not enough for AAA games, and the FX series is hard to beat at this price range. If you want to upgrade to an i5 and lack some performance now though, the i3 build will do just fine until you get the i5. If you don't plan on overclocking, just get a H97, Z87 or H87 board, as you can save some $ by getting a board that does not support overclocking.
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4634836
If you're willing to learn how to overclock (and you should be, the benefits are great to behold), you should probably go with the G3258. Use that to learn how to overclock, and then when you're sufficiently schooled in the process and have the money to do so, upgrade to a unlocked i5.
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4634844
i3, games like stronger cores, beside that i3 has Hyper-Threading which helps performance. Although the G3258 has big overclocking headroom.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4634851
I'd personally get either the i3 or the FX-6300. 2 cores is simply not enough for AAA games, and the FX series is hard to beat at this price range. If you want to upgrade to an i5 and lack some performance now, the i3 build will do.
actually games like DayZ and Arma suck hard with the FX builds
it works fine with Intel i3 CPU
and it has 4 treads which helps in most games
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4634852
for the sole reason minecraft is in that list the AMD falls out of question.
(EDIT: dont question this, i have plenty of experience to say this is a thing)
i'd suggest the i3 over both other options because it has much better single core performance than the AMD, and is better at multitasking than the pentium. (only get the pentium if you're only going to do one thing at a time, and if the games you play dont have optimalization for more than 2 cores.)
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4634864
I would get the i3 if you plan to upgrade later to an unlocked i5/i7 if you were not looking to upgrade on the same platform (aka future intel/ amd chipsets) I would get the FX 6300 and OC the crap out of it.
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4634904
Yes, I'll question that. why exatly will the AMD be SO much worse than an i3? i had a sandybridge i3 before my system now, and I can tell you that i wished for 2 years that I had gone team red. Many games, Minecraft included, along with BF4, HATED the two-core-four-thread mess that the i3 was. BF4 refused to run, period, and Minecraft had some crazy FPS drops. I can safely say now those were not as a result of the GPU (HD 7770) as I still use it now and I can now play BF4 on medium, with >70 FPS all the time.
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4634909
i can guarantee you minecraft will run worse on AMD than it will on an i3, i see this happen time in time again, where friends of mine get an AMD, and it runs like a joke compared to an intel. i've seen fps differences go up to twice the performance on intel over AMD. (even not alone in minecraft, a friend of mine had an issue with i7, having him swap to an AMD 8350, getting him barely half the FPS in H1Z1 as he got with his intel)
either these tests all had a random factor making it happen this way over and over, or -in fact- AMD's single core performance isnt as good as that of a haswell intel chip.
do note all these results where with haswell based intel, and i've seen the same kind of difference between nehalem and haswell.
EDIT: forgot to mention, for total performance intel has nothing in this price range that can compete, but a lot of games wont even use more than two cores. (minecraft uses one core, and a second one a bit, all source games use either one or two cores (configurable)
also, FPS drops in minecraft are usually more memory related than CPU related, minecraft works VERY weird... i've seen minecraft work fine one day, have fps drops the other, and be fine again the next...
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4635380
Well you're right: AMD's single core performance is nowhere near that of an Intel chip. Keep in mind that Minecraft is Java based, which explains its strange behavior and high memory needs. I still end up recommending AMD at this pricepoint though due to it's multi core performance, and I personally haven't had any 'bad' experiences with AMD processors in games. To each his own :)
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4637545
i completely agree with you on the multi core performance (and indeed, to each his own) i'm just here to say that for whatever reason it may be, minecraft + AMD its a terrible experience in most cases i've heard of (until you start recording a video or livestreaming, because there the other cores come in)
i'd actually have said the AMD chip if the only two games on the list i know werent games that only use 2 cores.
something that i have to say in favor of the AMD is that they (with adequate cooling) overclock trough the roof.
i'm still waiting on an intel 8-core that can hit 5.2 GHz stabile... (not applicable here though, since OP doesnt want to OC)
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4637611
For what games you plan on playing it won't matter terribly much what you get. The main thing would be if you'ld want to do things like play games while say searching the web on another display or window while listening to music. Intel is know for it's single thread performance making them a great choice for gaming; However, you'll probably run into issues while trying to do even mild multitasking, which is where the more cores on the 6300 will outperform the budget intel cpus.
One of my good friends actually has a system with nearly the same configuration as the amd build you listed. I was really pretty impressed with how well the fx6300 and 750ti handled games like cs:go, TF2, and even Borderlands 2 fairly well.
Current gaming build: Link to PcPartPicker
https://linustechtips.com/topic/339976-pc-build-help/#findComment-4638001
