4 pin fans are usually referred to as PWM fans.
I highly recommend Noctua NF-12 Fans. If you don't like the colours then let me assure you these are the best fans on the market.
After that I would say get Be Quiet Silent Wings 2 fans: Clicky
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/3397-fans-for-rad/#findComment-43157
FYI - do not go with Corsair SP fans - they do not play well with fan controllers... Check the link for a bunch of recommendations...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/3397-fans-for-rad/#findComment-43237
what about the air penetrators
Depending on the rad's FPI The AP-121 could work but on my H100 it doesn't do so well, 86c average on an Core i7 920 D0 @ 4.01 ghz
Motherboard: Asus ROG Crosshair VIII Hero (Wi-Fi) | CPU: AMD Ryzen 9 3900X | Memory: 32GB 3600mhz DDR4 | GPU: EVGA GTX 1080 Ti FTW3 |
Storage: Samsung 840 Pro 256gb, 850 Evo 500gb, 960 Pro 1tb | Cooling: Custom Liquid Cooling Loop (CPU/GPU) | Case: CaseLabs Mercury S8+Pedestal  | Monitors: Asus ROG Swift PG279Q + PA238QR
https://linustechtips.com/topic/3397-fans-for-rad/#findComment-43832
In that case the AP-121's would not be ideal. Consider the Gentle Typhoon 1850's (AP-15's), amazingly quiet for an fan that spins at almost 2000 rpm
https://linustechtips.com/topic/3397-fans-for-rad/#findComment-44110
Obligatory answer is GT AP-15's but they aren't PWM I don't believe. I'm currently running Noiseblocker Pro PK-3's on my Hardware Labs Black Ice GTX 560 and they are beautiful little fans IMO....
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
https://linustechtips.com/topic/3397-fans-for-rad/#findComment-44120
I've heard the exact opposite from people on OCN.
I think Dmantsaiu was one of the people that told me that (probably spelling that name wrong)
https://linustechtips.com/topic/3397-fans-for-rad/#findComment-44163
Well I tested it with a bunch on my BitFenix controller- contacted Corsair support and they confirmed this. Their SP series do not work on a lot as the majority of controllers have variable voltage regulation (or something to that effect). At any one setting the voltage is always moving up and down slightly. They want a constant voltage.
https://linustechtips.com/topic/3397-fans-for-rad/#findComment-44165
i never use a fan controller, but there have been many remrks on SP/AF on fan controllers.
i use a molex and hard-wire voltage or a resistor and no ill issues (contant voltage).
its kinda like Linus described it, how many times will you be jacking around the control knob?
many fans get wrecked reps because of fan controller issues.
hard wire a voltage or buy a proper fan... my two cents.
https://linustechtips.com/topic/3397-fans-for-rad/#findComment-44234
