I saw a build which said to add intel core i3 4360 but what if i add intel core i5 4460?? would it effect the build or something else would happen please help!!
THe build is
Motherboard  GA- Z97-D3H
cpu core i3 4360
ram 8GB 1600Mhz DDR3 (4×2)
drives 120GB SSD , 1TB HDD
power supply Corsair CS 550 Watt Modular
Case NZXT 210
wifi card TP-Link PCI Express Wifi Adapter
And which gpu should i use with the build??
https://linustechtips.com/topic/339500-build-question/
What is your budget for the full system?
The Rig: NZXT H440 M3 (Green and Black) (Ncase M1 coming soon!!) | Intel Core i5-4690k x BeQuiet PureRock Slim | EVGA GTX 1060 6GB SSC  | ASUS H81i Plus | 12GB EVGA SSC @ 1600MHz | Seagate Barracuda 2TB | Sandisk Ultra II 480GB | Corsair SF 450| LG 29" Ultrawide | CoolerMaster Quickfire Rapid TKL | Corsair M65 Black Sennheiser HD 558 (MOD) | Audio-Technica ATR 2500
https://linustechtips.com/topic/339500-build-question/#findComment-4628689
Where are you located and how much are you willing to spend?
Also, what do you want to accomplish with the build?
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/339500-build-question/#findComment-4628847
