Is there any difference in a optical cable when it comes to sound?
Since Spotify has finally come to Playstation i can use it for music, but i use a Optical cable to my receiver with my ps3, the audio however sounds kinda shitty on the ps3 compared to what i get on the AUX on pc and my phone.
https://linustechtips.com/topic/339491-question-about-optical-cable/
Optical cable is superior to just about everything on the planet. The S/PDIF transport used by most consumer electronics, however, has it's limits.
I would check to make sure the console is set to stereo (for testing only, I'd nothing else), and that your cable has no kinks in it.
S/PDIF is fine for stereo sound, 5.1 needs to be compressed.
Remember your soundcard may emphasise the bass and/or adding a bit of echo so you have the feeling of a "full" sound.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
