Did you format it?
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624254
it wont let me
What do you mean it won't let you?
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624269
error message says win cant format system partition on this disk
Are you formatting the correct drive? You can't format a drive in use by Windows.
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624316
yes
Please provide a full screenshot.
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624466
And you right clicked on Unallocated?
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624815
that option isnt available
What do you get when you right click on Unallocated?
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624853
Use in Win 8.1 installer to see if that helps. Why is your System Reserved on your HDD?
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624865
That can sometimes happen. It's a common issue when another storage drive is plugged in other than the intended boot drive. That may be where OP's issue lies.
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624883
snip
Is that a Segate 3TB drive. If so I think you may need a new drive. I had a very similar problem not too long ago. Windows wouldn't recognise it at all. If you open your case can you hear a beeping and ticking noise? I found out for certain that mine was broken by using a Linux machine. I was able to get more info from the Disk Utilitly than I could from Disk Management in Windows.
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624884
He could Try reinstalling Windows but disconnect the HDD.
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624896
yeah it is, hmmm no noise
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624918
new simple volume...
properties
help
Can you create new volumes? I couldn't so if you can then its a different issue.
Open the case and stick your ear in. The noise isn't very loud (if there is one).
In case you were wondering why the drive seems to be split into a 2TB and 1TB drive, that is a limitation of MBR partitioning. If you do manage to get it working (or when you get your next 3TB drive if it is broken), format the drive using a GUID partition table and you will be able to create one large 3TB drive (or 2.7TB when its NTFS)
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624940
i created a new volume, 1.99 tb but the other partition isnt letting me do the same
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4624976
properties
help
Click New Simple Volume.
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4625019
Hmmm. I am not too sure. It is possible that it still has issues and that only the last TB is corrupted. Then again I have always found formatting to be tricky in Windows. Linux is far superior for formatting. Things just tend to work far more often.
If I were you, I'd download Linux Mint, install it to a USB stick using Win32DiskImager and then boot into the Linux machine using Linux Live. You will be able to boot directly into the OS from the USB (i.e.without having to install Linux). From there you can run Disk Utilities and try format the drive there. If you can't fix it any other way (or if you have a really fast internet connection), try this as it is a sure way to get to the root of the issue.
https://linustechtips.com/topic/339126-hd-not-showing-up/#findComment-4625052
