Ive been planning this build for a while and need some final advice
Link:
http://uk.pcpartpicker.com/p/fHBHK8
Note: Gpu will probably be a r9 380x and I will use a old monitor till then
Main usage: Gaming, all round homework station and possibly some light video editing in the future
Budget: Not including monitor and gpu, around £750 max
CPU: No need to get anything better at the moment
CPU Cooler: Is quiet, looks good and dosnt get in the way of my high profile memory
Mobo: Great looks, great internal dac, great bios and ek has a waterblock for it which i may use as I am planning on doing a full custom loop
Mmemory: Very well regarded and goes with my black/red/white color scheme
Storage: Suites my needs nothing more to say
Case: Great case in general and has a lot of watercooling support, which I hope to be taking advantage of in the future
PSU: Ample wattage for even dual 970s, fully modular and has great sleeving
PS im looking for an amp to drive my dt990 250oms an suggestions?
https://linustechtips.com/topic/339099-first-build/
Link:
Seems good. As long as you can justify your choices there isnt much to change
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
https://linustechtips.com/topic/339099-first-build/#findComment-4624048
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£173.00 @ Amazon UK)
CPU Cooler: be quiet! Shadow Rock Slim 113.8 CFM Rifle Bearing CPU Cooler (£32.29 @ Amazon UK)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard (£89.99 @ Amazon UK)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory (£52.36 @ Amazon UK)
Storage: Crucial MX100 256GB 2.5" Solid State Drive (£73.02 @ Amazon UK)
Storage: *Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£42.95 @ CCL Computers)
Case: Phanteks Enthoo Pro ATX Full Tower Case (£84.59 @ Overclockers.co.uk)
Power Supply: SeaSonic EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply (£67.94 @ Scan.co.uk)
Other: Powerline Adapter (£25.00)
Other:
Other: Windows 8.1 (£25.00)
Total: £666.14
Generated by PCPartPicker 2015-04-01 00:41 BST+0100
Fiio E10
Steve
https://linustechtips.com/topic/339099-first-build/#findComment-4624057
