Does SSD speed make a difference with OS?
I've currently got my windows OS running on a Samsung EVO 256GB SSD. I've recently purchased a new Samsung SM951 512GB m.2 SSD for my games and I was wondering, considering that the m.2 has a significantly higher read and write speed:
1. Would I see performance increase with my operating system if I put it on the new SSD.
2. If I DIDN'T put my OS on the new SSD, is there any chance that the read and write speed of the games that I DO put on it, could somehow be bottlenecked? Eg. BF4 on m.2 - origin app on Evo SSD - cpu.
What I'm asking is, is there any thing bad (speed wise) that could come from not moving my OS to the new SSD? What is the max speed my OS would even use? Is my current SSD Sufficient? Or should I transfer it to the new one.
Thanks.
Hey AmirMC,
It would make a difference if the read/write speeds are great and they are not bottlenecked by the SATA port. SATA 3 (6Gb/s) has a limitation of 750MB/s. Since this is a PCIe SSD you would have greater speeds than SATA storage drives and your boot time should be less as well as all loading times on applications and games on that SSD and transfer speeds should be even higher. SATA SSDs are already fast enough to have a very responsive build, but you would have to use heavier applications to actually see the additional speed increase from the PCIe SSD.I don't think anything would bottleneck the PCIe SSD (in your system).
Your current SSD should be sufficient enough. If you happen to transfer the OS, I would strongly suggest doing a fresh install rather than cloning it as the PCIe SSD could be recognized as a SATA one and cause some problems.
Captain_WD.
