Hey everyone,
finally building my FIRST PC!!! I'm a software developer by trade and have been installing ram/gpu in and out of computers for years so I'm tech savy and not a complete noob. With that being said I am new to everything else and I understand this probably isn't the best build for a beginner but I've never been one to back down from a challenge =)
Let me first start off by saying that I have done a fair bit of research and understand I could probably find alot if not most of these answers on my own. However since it is my first time building a PC and I'm going to be spending a fair bit of money on this machine I would like to have some reassurance from veteran PC builders that I'm taking the right path.
Now for the build.
Budget:
Lmao just kidding. I don't really have a budget. Although I would like to keep it under the $2,000 mark and preferably below $1500. I'm also not against buying "gently" used parts if its a bargain and in good shape.
Goals:
  1. Portable
  2. Quiet
  3. 1440p gaming preferred at least 60hz
  4. HTPC
Parts: (*** means not set in stone and still open to ideas)
  • Case    : Ncase m1 V3 - $225
  • Drive 1 : WD Red WD60EFRX 6TB (Not counting in budget)
  • Drive 2 : Unknown SSD - 512gb
  • GPU     : gtx 970***
  • PSU     : SILVERSTONE SFX Series SX600-G 600W***
  • Cooling : Arctic Accelero Hybrid II-120***
  • CPU     : ?***
  • Mobo    : ?***
  • Ram     : ?***
  • Optical : ?***
Thought process on parts above:
  • Case    : Already purchased and seems to fit the bill. From what I've gathered is the general consensus is people are very happy with this case. I didn't mind splurging for a well built and aesthetically pleasing case =)
  • GPU     : Low TDP, powerful, quiet, and great bang for buck. Not sure if I should go for the mini or the full card. What are the pros and cons of each? Is one quieter or produce less heat?
  • PSU     : Noise. I'm aware that 600W MIGHT be overkill but if I'm correct it will run quieter since it isn't having to ramp up under load.
  • CPU     : I want something that isn't going to bottleneck my GPU. Willing to spend around $250ish but not sure if it's necessary
  • Mobo    : NEED wifi connectivity for HTPC concept. I don't really know where to start other than that. I've read if I want to overclock I need a Z series board and that their wasn't really any improvements since the z7* series
  • Ram     : 8gb or 16gb. Not sure on this one. Is 16gb overkill? Maybe buy a single 8gb stick now and buy a 2nd one down the road, or is 2x4gb > 1x8gb?
  • Optical : the cheapest blu-ray player that can also stand the test of time. Shouldn't see to much use. I figured I should have one since this machine will double as an HTPC
  • Drive 1 : I have had this drive for a while now and it stores all of my media. Hints why it is a requirement
  • Drive 2 : Just need a cheap AND reliable 512gb SSD
  • Cooling : I really have no clue where to start on this. The main reason why I thought of water cooling was for sound reasons. If I could get a quiet machine with fans I'm open to that as well.
Main Concern:
  • What kind of water cooling setup can I use with 970(full or mini) with 1 x 3.5" hdd and 1 x 2.5" ssd
I appreciate everyones time for looking at this and am very grateful for all input to come! and sorry if I missed anything :P
https://linustechtips.com/topic/338622-ncase-m1-1500-build/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.99 @ SuperBiiz)
CPU Cooler: Corsair H80i 77.0 CFM Liquid CPU Cooler  ($79.99 @ Newegg)
Motherboard: Asus Z97I-PLUS Mini ITX LGA1150 Motherboard  ($148.99 @ SuperBiiz)
Memory: Kingston Fury Black Series 16GB (2 x 8GB) DDR3-1866 Memory  ($123.98 @ NCIX US)
Storage: Crucial MX100 512GB 2.5" Solid State Drive  ($202.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($329.99 @ Amazon)
Power Supply: Corsair Professional 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Newegg)
Case Fan: Cougar Vortex PWM 70.5 CFM 120mm  Fan  ($14.98 @ SuperBiiz)
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm  Fan  ($22.57 @ Amazon)
Other: NCase M1 V3 ($250.00)
Total: $1593.45
Generated by PCPartPicker 2015-03-31 00:03 EDT-0400
You don't need a liquid cooled graphics card, the Strix fans only turn on when they need to.  The N-Case M1 doesn't come with any fans, hence the trio.
sold
https://linustechtips.com/topic/338622-ncase-m1-1500-build/#findComment-4617566
How do you like the STRIX card vs the MSI? I read that it was more quiet.
and how quiet are the PSU and the Cougar Vortex fans?
I appreciate you taking the time to help me!
https://linustechtips.com/topic/338622-ncase-m1-1500-build/#findComment-4617637
I have the fans, and the upgraded version of the PSU, both are whisper quiet.  Psu has zero fan modes, and fans are turned down automatically.
sold
https://linustechtips.com/topic/338622-ncase-m1-1500-build/#findComment-4617850
Storage: Crucial MX100 512GB 2.5" Solid State Drive  ($202.98 @ Newegg)
Power Supply: Silverstone 600W 80+ Gold Certified Fully-Modular SFX Power Supply  ($117.99 @ Directron)
Other: NCase M1 V3 ($225.00)
Total: $1606.44
Generated by PCPartPicker 2015-03-31 22:08 EDT-0400
Updated.
sold
https://linustechtips.com/topic/338622-ncase-m1-1500-build/#findComment-4625032
