Need Python failsafe help
Solved by madknight3,
This should help
What's the canonical way to check for type in python?
Python - Determine the type of an object?
There's also the saying "it's better/easier to ask for forgiveness than permission". Some people like to apply this to coding in certain situations. Basically, work with the information as if it was correct and use a try/except statement to handle when things go wrong.
