Are there certain audio and LAN chipsets that I should look for when shopping for a motherboard? Or conversely, are there chipsets that I should avoid? I'm not going to base my entire decision on these components, obviously. Rather, I hope this will help me decide between boards that meet my needs.
I've read that Realtek ALC1150 and Intel LAN (any chipset?) are good.
I plan to use the HyperX Cloud/Cloud II headset if this matters. I might get a higher-end pair of headphones in the distant future.
EDIT: Keep in mind that I'm interested in a Z97 board under 160 CAD.
i5-4690K@4.5 GHz // Asus Z87-Pro // HyperX Fury 8GB DDR3-1600 // Crucial BX100 250GB // Sapphire Nitro R9 390 // EVGA SuperNOVA 750W G2 // Fractal Design Define S // be quiet! Pure Rock & Pure Wings 2 // BenQ XL2730Z // Corsair Vengeance K70 // Logitech G403 Wireless // Sennheiser HD 598 SE
https://linustechtips.com/topic/338040-audio-and-lan-chipsets/
There are audiophile motherbaords out there.can't comment much about audio chipsets,but yeah intel's Lan is awesome.
When everything else Fails,Crowbar IT. - Half-life
Being a Linux user is sort of like living in a house inhabited by a large family of carpenters and architects. Every morning when you wake up, the house is a little different. Maybe there is a new turret, or some walls have moved. Or perhaps someone has temporarily removed the floor under your bed." - Unix for Dummies, 2nd Edition (Found in the .sig of Rob Riggs)
https://linustechtips.com/topic/338040-audio-and-lan-chipsets/#findComment-4610063
I forgot to mention that I'm looking at budget Z97 boards (<160 CAD) so audiophile components might be too much.
https://linustechtips.com/topic/338040-audio-and-lan-chipsets/#findComment-4610128
Realtek chipsets perform quite decently
i wont worry too much about them giving problems
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/338040-audio-and-lan-chipsets/#findComment-4610145
Is there a perceivable difference between ALC1150, ALC898, and ALC892?
https://linustechtips.com/topic/338040-audio-and-lan-chipsets/#findComment-4612215
