So we all know the stock cooler is free, mid range air coolers are 30-ish bucks, and aio's range from 40-200
But what is the real cost of a custom loop only cooling one gpu and the Cpu ( 1x 240mm rad and 1x 120mm rad)
How cheap can a loop actually be made without compromising/harming components?
Edit: I ask because I was contemplating starting to design my own case (clockwork themed) and maybe do a small copper loop inside
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/337986-how-much-does-it-cost/
I would say easily 600 or 700 dollars. Kinda depends on the parts you're getting and the amount and size of rads you'd be using.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/337986-how-much-does-it-cost/#findComment-4609156
how about cpu only loop? as the gpu could be added later..(looked at plates and they are 100 bucks minimum a pop lol)
only 1 240mm rad btw
https://linustechtips.com/topic/337986-how-much-does-it-cost/#findComment-4609170
You could probably get that in a kit for around 400.
https://linustechtips.com/topic/337986-how-much-does-it-cost/#findComment-4609184
Not bad I'd much rather have this over a h100 or something and it's not that much more
https://linustechtips.com/topic/337986-how-much-does-it-cost/#findComment-4609325
most buy the AIO for convenience, lack of knowledge, or not skilled to take on
the task of DIY water cooling. some look at it that a $30 air cooler is a well to-do
as spending $150 on water cooling. in most cases, that could be true, but flip
side of it all is that there are many that get 30° better in CPU temperatures over
the air HSF systems. is it worth it, the wallet, confidence and effort will tell.
https://linustechtips.com/topic/337986-how-much-does-it-cost/#findComment-4609363
True, If only these were cheaper than an aio I wonder how they would sell then
https://linustechtips.com/topic/337986-how-much-does-it-cost/#findComment-4609491
