Switch Default Playback Device with Programable Keys.
Use a headset as well as speakers?
Like to use to your headset for gaming but like to use your 5.1 speaker system to watch movies?
Sick of changing the default device manually?
Well if you have programmable keys you can assign them to switch your device.
Tutorial as followed:
_____________________
1) Download NirCmd from http://www.nirsoft.net/ and place some where nircmdc.exe convenient.
2) Create two text files like below and place them with in the same folder as the exe file:
File 1________________________________
Text file name:
SwitchToSpeakers.ncl
Contents:
setdefaultsounddevice "speakers"
setdefaultsounddevice "speakers" 2
____________________________________
//Note, quotes ARE used in code.
File 2________________________________
Text file name:
SwitchToHeadphones.ncl
Contents:
setdefaultsounddevice "headphones"
setdefaultsounddevice "headphones" 2
You may have to adjust the text inside the quotes to match your system. (manpage setdefaultsounddevice)
3) Then go to the G-key setup and choose shortcut. Here you want to put the following: (remember to adjust the path)
Key that switches to speakers:
X:=PATH/TO/nircmdc.exe script SwitchTo"Your Speaker Name".ncl
//e.g. witchTo"Speaker".ncl
Key that switches to headphones:
X:=PATH/TO/nircmdc.exe script SwitchTo"Your Headset Name".ncl
//e.g. witchTo"Headset".ncl
Enjoy!
