Led fans, maybe uv?
Swiebertjeee
I want to switch my fans in my midi arc r2 ( I think they're 120mm) I use the fans that came with the case nothing wrong with them I have a really cool temp, but I want LED fans to let my case shine :)
I have two questions:
Which LED fans would you guys recommend with led lighting, i preffer UV lightning?
I currently have 3 fans in my case and my case is pretty cold, but I want to add another one because it will look better. But will my pc become under-cooled if I do this?
Beneath this mask there is an idea, and ideas are bulletproof.
MOBO and CPU temp have 30 degrees celcius when computer is in standard use. Maybe a little bit lower on startup
You can't "undercool" a pc....
There are no LED fans that I know of, that offer good performance, and silence. You're best off buying UV LED strips online, and just placing them in your case, with good quality fans.
If you're achieving good temps with 3 fans, stick with three. The 4th it just unnecessary noise and power consumption.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
most fans that are UV, are UV reactive, and don't give off UV. like linus likes to use UV reactive blue GELID WINGS
