I got my gaming pc but now i need to put the fans and i dont know on what derection to place them i mean i dont know in what direction to air flow couse i have now 2 fans and 1 is on back and 1 on front and bouth of them flow air inside the case so can someone help me about this .. ?
https://linustechtips.com/topic/336825-k350-air-flow-help/
in the front, out the back.
out the bottom if you have bottom fans.
flow of the top is up to you.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/336825-k350-air-flow-help/#findComment-4595529
u mean the front to take air and the back to flow air out side the case ?
yes. suck air into the case at the front, blow air out of the case at the back.
also, 2 fans are not much. you might want to add more down the line.
https://linustechtips.com/topic/336825-k350-air-flow-help/#findComment-4595541
what about the bottom and the side ? :P
suck in fron the sides, push out the bottom (for dust reasons)
https://linustechtips.com/topic/336825-k350-air-flow-help/#findComment-4595552
but on the bottom i have 2 dust filters :/
if you push air out that way you'll never have to clean them. if you suck air in that way you'll clean them every 2 weeks to 2 months. (you won't really, but you should)
https://linustechtips.com/topic/336825-k350-air-flow-help/#findComment-4595611
idk :P ill see firsti need to change my back fan now so ty for the help buddy :D
https://linustechtips.com/topic/336825-k350-air-flow-help/#findComment-4595635
NP, good luck!
https://linustechtips.com/topic/336825-k350-air-flow-help/#findComment-4595647
