Help with maths homework again please :)
Anyways, just use the scale factor 2.5 (you find this out by doing 48.5/19.4) on whatever you want to find out, I think that's what you're supposed to do
"My game vs my brains, who gets more fatal errors?" ~ Camper125Lv, GMC Jam #15
x is 46.3351
y is 21.1017
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
Thank you very much :) 100% master race :P
you find the ratio of 2 sides of one triangle to get the the side of the 2nd triangle
19.4/20.2 = 44.5/X
unless those aren't corresponding sides. it's hard to tell.
It's so easy D:.
19.4/48.5 = y/44.5 = 20.2/x
Thanks for the help, but it was 50.5 and 17.8
Yes
oh, well read above, i picked the wrong corresponding sides.  been a while since i've done this.
Y= 20.22 + 19.42 = 784.4
the square root of 784.4 = 28.0071419
that only works for right triangles.
It should be like this:
19.4/48.5=y/44.5
You'll find the Y.
Do cross multiplication.
Then...
19.4/48.5=20.2/x
You'll find the X.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
When everything else Fails,Crowbar IT. - Half-life
Being a Linux user is sort of like living in a house inhabited by a large family of carpenters and architects. Every morning when you wake up, the house is a little different. Maybe there is a new turret, or some walls have moved. Or perhaps someone has temporarily removed the floor under your bed." - Unix for Dummies, 2nd Edition (Found in the .sig of Rob Riggs)
yep, that was it :) thanks
rule of thumb in these things:
color the simmilar parts of the triangle for easy visualisation
then always divide the bigger one by the smaller one to get a ratio and then
multiply small by ratio for big
divide big by ratio for small
19.4/48.5=y/44.5
You'll find the Y.
Then...
19.4/48.5=20.2/x
You'll find the X.
If you're still confused on what I mean, you can think of this:
A/B=C/E=D/F
PC Specs
Indonesia
Australia
It's not to do with pythagoras, it's a homework that's for getting used to similarities.
Ahhh shit why'd you have to quote me so quick now i look like a dumbass :/ I immediatly realized my mistake and edited the post :P
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
