Hey, I accidentally formatted my System Reserved Partition (350mb) while doing a clean installation, now I can't install Windows and I can't boot into Windows as it says that " An operating system wasn't found. Try disconnecting any drives that dont contain an operating system. Press any key to restart". Please help me.
What do you mean you can't install Windows? Windows should still install fine - when I do a clean install, I usually remove my partitions and start over.
