possible problem with blue yeti usb
So currently i only have a labtop with a dedicated graphics for gaming as my pc build is a slow process but i regulary game on it using an external moniter keyboard and mouse. my problem is it only has 3 usb ports (1 usb2 2 usb 3) one is used with an external harddrive holding games while a mouse and keyboard use the others. would using a usb hub with the mic cause problems . if not what do you reccomend
https://linustechtips.com/topic/336687-possible-problem-with-blue-yeti-usb/
A USB hub or splitter should be fine
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
