How much OHM do i need?
Headphones with high impedance are usually good, but the headphone's impedance has nothing to do with the sound quality. Headphones with high impedance generaly benefit from a good amp, so that's usually a drawback instead of a benefit.
Since you have a decent on board amp, then the Beyerdynamic are great headphones. The beyers and M50X are very agressive sounding headphones, while the sennheiser are more natural and relaxing. The Sennheiser and the Beyerdynamic are extremely comfortable headphones that you can wear more than 3 hours without any fatigue.
All of them have the same sound quality (if this makes sence), but they sound different.
Comfortability:
HD558=Beyerdynamic DT990 >= Beyerdynamic DT770 > M50X.
Agressive-ness: (treble)
DT990 > DT770 > M50X > HD558.
Bass:
DT770 >= M50X > DT990 > HD558
So, if you want a relaxing sound, check out the HD558 & HD598.
If you want an agressive sound, then you have to decide if you want open or closed headphones. If you want open, then the DT990 is an excellent option (i have a pair). If you want closed then i would suggest you to get the DT770 because are much more comfortable than the M50X. However if you want a more natural tone, then the M50X is also an amazing choise.
Finally, check out the new AKG 553 or the older AKG K550. They sound a bit lean, but they are very good headphones (never tried them though...)
