Servers without port forwarding?
Go to solution Solved by markoskerass,
If all the computers are going to be connected at the same router then having a localhost server is possible.
Min requirements for ts: http://www.teamspeak.com/?page=requirements
About csgo i cant really help. Creating a localhost server works the same way I explained above
So, I might host a small lan(15-20 people), hoping it will turn into something slightly bigger. I was wondering.
I might not be able to get access to the router where it will be hosted, will a local teamspeak/csgo server work without port forwarding? It does not need any traffic going outside the local network.
And what are the requirements for running small servers like that? TS(20man) and CSGO(10man) on the same pc? Currently all I have available is a shitty laptop (i5 3230m, 8gb ram).
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
https://linustechtips.com/topic/336313-servers-without-port-forwarding/
CPU: AMD FX 6300 4.6 GHZ 1.392vCore ||||| Cooler: Hyper 212 evo ||||| MOBO: Gigabyte 990XA UD3 REV 3.0 ||||| RAM: Kingston Hyperx Fury (Single channel) 1866 8GB CL10 ||||| GPU: Sapphire HD 7770 1GB ||||| PSU: CoolerMaster G550m 80+ Bronze ||||| SSD: Kingston SSDnow v300 ||||| HDDs: 2x 250gb 1x Wedstern Digital 320gb |||| Case: CoolerMaster Silencio 650 Black Pure Midnight
Thank you very much. I didn't really expect anyone to know much about CS, but you answered my questions :D
