Posted March 26, 2015 Hello LinusTechTips Forum dwellers! I was thinking of making a build using the Intel Core i7-4790k and GTX Titan X (once there's more stock >.>) however I've never done a build of such high power consumption before and I knew that this was the best place to get recommendations from first. I definitely want 80+ Platinum, or Gold if it means a better PSU. I'm honestly not too sure exactly how much I should go over TDP in watts as I've also never done heavy overclocking but with a build like this I want as much power as I can squeeze out of it! Link to comment https://linustechtips.com/topic/335321-power-supply-recommendation/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2015 Hello LinusTechTips Forum dwellers! I was thinking of making a build using the Intel Core i7-4790k and GTX Titan X (once there's more stock >.>) however I've never done a build of such high power consumption before and I knew that this was the best place to get recommendations from first. I definitely want 80+ Platinum, or Gold if it means a better PSU. I'm honestly not too sure exactly how much I should go over TDP in watts as I've also never done heavy overclocking but with a build like this I want as much power as I can squeeze out of it! Evga 750w g2, best psu in it's class. If you plan on doing sli with those bad boys maybe get an 850w. 750 will manage but it's always nice having headroom. Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q Link to comment https://linustechtips.com/topic/335321-power-supply-recommendation/#findComment-4573805 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2015 Well Titan X's power draw is relatively low, so I suggest something like an 750-800w gold PSU. I don't generally look at platinum PSUs just because gold certified serve their purpose almost as well for a lower price. CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified Link to comment https://linustechtips.com/topic/335321-power-supply-recommendation/#findComment-4573819 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2015 Go for EVGA, Cosair, Coolmaster, Silversonic 750-900watts. It low power compare to the AMD GPU. Magical Pineapples
