Hallo friends, to try getting a better overclock I changed my Base Clock instead of only changing my multiplier.
My Base Clock is 109 with a multiplier of 44 (4.8 GHz), and my ram is running at 1700 MHz
Should everything be fine or is there anything else I need to change?
1.362 V btw
Temps are fine, I know degradation is a thing but I'm not concerned
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/335268-help-with-base-clock-overclocking/
My Base Clock is 109 with a multiplier of 44, and my ram is running at 1700 MHz
Why do people change base clock?
Always wondered :P
Always wondered :P
I hear it may help stability so I gave it a shot :P
Oooooooooooo, how?
Somebody needs to help me with this :o
Always wondered :P
Dont base overclock ever, Its the worst type of OCing. Stick to Multiplier.
The thing about your BLK clock is that its used by many of the buses and chips on your motherboard to determine there speeds and things like that, including PCI-E rates that are set at 100 by default.
Bumping your BLK means that your forcing some buses and other parts of the motherboard faster than what they should be going (they are not built for OCing). Typically what you will find first is some system instability in the form of your GPU driver crashing in games (as you have adjusted the BLK clock from its 100 its now out of spec of PCI-E and causes issues).
Quack 🦆
Alright, I put it back to auto :P
in other news my new voltage is 1.337 V lol
