Need help building a pc around 800 dollars ( u.s.) does not need to be exact but close. I am new to the pc world so please do not make it especially optimized for overclocking because i probably will not over clock it. I do not need a monitor and have no parts at all so everything is needed. Thank you to all of you that respond.
https://linustechtips.com/topic/335224-800-us-dollar-pc-build-help/
you could try this
Graphics card - Gigabyte GeForce GTX 960 OC 2GB
power suplly and case - EVGA Hadron Air Mini ITX Case with 500W
CPU - Intel Pentium Anniversary Edition G3258
Motherboard - ASRock H81M-ITX Motherboard
Memory - Kingston Hyper X Fury HX318C10FBK2/8 8GB (2x4GB) Black
Storage - Seagate Barracuda 1TB ST1000DM003
this should be about your budget sorry i di not add links iam Australian and was to lazy to find US sites but it should be your budget
Thanks
IAN
IAN :o
I undercut your budget a little bit and still got decent power without using any kind of oc. Although the CPU and MotherBoard both do not support overclocking at all. If your looking to do so in the future youll need a new CPU AND MOTHERBOARD. Also this will run everything at 1080p with some head room. My personal build is similar and just destroyes games at 1080p and several at 1440p. Love the 280x lol.
CPU: Intel Core i5-4590S 3.0GHz Quad-Core Processor
CPU Cooler: be quiet! Shadow Rock 2 87.0 CFM Rifle Bearing CPU Cooler
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
               Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card
Case: NZXT S340 (Black) ATX Mid Tower Case
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm  Fan
Total: $777.34
http://pcpartpicker.com/user/ShawnWilliams/saved/G48CmG
Consume The Darkness
PCPartPicker part list: http://pcpartpicker.com/p/GYtKRB
Price breakdown by merchant: http://pcpartpicker.com/p/GYtKRB/by_merchant/
CPU: Intel Xeon E3-1220 V3 3.1GHz Quad-Core Processor  ($194.95 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($73.98 @ Newegg)
Memory: A-Data XPG V1.0 16GB (2 x 8GB) DDR3-1600 Memory  ($99.99 @ Newegg)
Storage: Seagate Barracuda ES 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ Amazon)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card  ($249.99 @ Newegg)
Case: BitFenix Neos White ATX Mid Tower Case  ($33.99 @ NCIX US)
Power Supply: Rosewill Capstone 550W 80+ Gold Certified ATX Power Supply  ($39.99 @ Newegg)
Total: $784.30
What I got.
Total: $784.30
What I got.
That Xeon doesn't have HT and has a lower clock than the cheaper i5 4590.
Total: $777.34
If you were to upgrade something and put more money say 850 or 900 what would you upgrade
Total: $784.30
What I got.
Ok dumb question I see this radon all over the place is it better than a gtx 970 or 960
you could try this
Thanks
IAN
Don't sweat it and I can easily look it up
This includes keyboard/mouse and OS But I wasn't sure if you wanted headphones or speakers so I didn't add those in.
PCPartPicker part list: http://pcpartpicker.com/p/YwfFMp
Price breakdown by merchant: http://pcpartpicker.com/p/YwfFMp/by_merchant/
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($214.99 @ NCIX US)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($71.99 @ SuperBiiz)
Memory: G.Skill NS Series 8GB (2 x 4GB) DDR3-1600 Memory  ($55.98 @ Newegg)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive  ($43.53 @ Amazon)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($199.99 @ Newegg)
Case: Cooler Master HAF 912 ATX Mid Tower Case  ($52.98 @ NCIX US)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($51.49 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($89.99 @ NCIX US)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($27.87 @ Amazon)
Total: $808.81
Generated by PCPartPicker 2015-03-25 19:55 EDT-0400
CPUAMD FX 8320 @4.4 GHz 1.212 vcore Motherboard - Asus M5A99X R2.0 RAM - G.Skill Ripjaws X 16 GB 1866 GPU - Asus Gtx 970 Case - Corsair Vengeance C70 Military Green Storage - 120 GB Samsung 840 Series, 1TB WD Black,  240 GB Corsair Force LX PSU - EVGA 750W G2 Cooling - Noctua NH-D14 Keyboard Corsair K70  Mouse - Logitech G502
This has the absolute best GTX 970 on the market as well as a very good i5. I edited my build to include the previously recommended Rosewill Capstone 550W PSU and the Cooler Master HAF 912 case, as they are better recommendations than what I originally chose in my suggested build.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($193.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($321.98 @ Newegg)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm  Fan  ($4.99 @ NCIX US)
Total: $801.38
Generated by PCPartPicker 2015-03-25 20:00 EDT-0400
Total: $808.81
I do not need a keyboard and mouse but i will need a operating system so thank you for the build.
You're welcome. I would recommend you just look it over and make sure everything looks good to you or if you have any questions about anything :)
Total: $801.38
I am completely new to the pc world how much better is the i5 4690k than the one you listed.
Not much unless you're trying to push 120 fps, which you're not doing on an $800 build. GPU overclcok matters way more, and that build has the best over clocking GTX 970.
Agin compelty new to the computer world do you think this would be a easy computer to build. ( as easy as a computer could be to build )
Total: $801.38
If you were to upgrade one thing what would it be.
