My friend has a business and its less than a half mile away from his house. It's in a residential area and not many trees around. Is it possible to send his WiFi signal across to the business? Would his speed be degraded??
Yes, and Yes + higher ping
https://linustechtips.com/topic/335205-long-distance-wifi/#findComment-4571915
You probably wouldn't be able to send WiFi that far, but you could definitely use a point-to-point link like Ubiquiti airMax https://www.ubnt.com/products/#all/wireless
His speeds would likely degrade, but these ptp links are relatively fast, so if there is line of sight the degradation would be minimal.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/335205-long-distance-wifi/#findComment-4572022
