I've been saving up for quite a long time now and I'd really like to build my own PC. I have around £600ish but would like to leave £100 or so for monitor and basic peripherals. The budget for the PC itself is around £500. Would like it to be micro atx for space reasons. I was thinking about something like a Pentium G3258 + z97 mobo (for future upgradeability) + a 280 (or something like that) but would like to see what other people are thinking. I can buy second hand parts from cex, such as Pentium K for like £30, but would prefer to buy new if it could give a decent build. For the last 1-2 years I've been using my laptop (with integrated graphics) and I sometimes play games such as tf2 but my laptop can't really handle more than that - When I build the computer
I'd like to be able to play game like war thunder or warframe at 1080p on reasonable settings.
Sorry if I rambled too much or left something out  ;) and thanks in advance!
Written on my Lenovo Z500 T - I5-3230M   Or
My pc :)
https://linustechtips.com/topic/335179-first-build/
If I was you, I would go with a AMD APU.  But if you're really dedicated to Intel, grab a i5-4670k or something similar and use the onboard graphics for a while.  Once you get $200 or so, grab you a video card then.  You'll be much more pleased.
If you want a actual build recommendation send me a message.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/335179-first-build/#findComment-4571396
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£62.36 @ Scan.co.uk)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1866 Memory  (£53.76 @ Amazon UK)
Video Card: Asus Radeon R9 270X 2GB DirectCU II Video Card  (£129.98 @ Novatech)
Case: Corsair 200R ATX Mid Tower Case  (£46.39 @ Aria PC)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  (£40.25 @ Aria PC)
Total: £479.05
Generated by PCPartPicker 2015-03-25 20:35 GMT+0000
https://linustechtips.com/topic/335179-first-build/#findComment-4571431
This fits the bill pretty well.
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  (£84.12 @ Aria PC)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  (£67.99 @ Amazon UK)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  (£72.94 @ Aria PC)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  (£139.98 @ Amazon UK)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£32.86 @ CCL Computers)
Total: £497.48
Generated by PCPartPicker 2015-03-25 20:51 GMT+0000
Just saying the 280x for £130 is out of stock (I've been hoping they restock it), so i may drop the SSD and then add as a future upgrade
So it is, I'd personally recommend getting a 256GB SSD first then getting a harddrive later as adding the SSD later can be quite a headache.
I've edited in a 280 that is in stock, the SSD can be swapped for a 2TB barracuda if you'd prefer to go that route.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/335179-first-build/#findComment-4571525
Storage: Kingston Fury 120GB 2.5" Solid State Drive  (£47.00 @ Amazon UK)
Video Card: MSI Radeon R9 280X 3GB TWIN FROZR Video Card  (£129.86 @ CCL Computers)
Total: £499.76
Generated by PCPartPicker 2015-03-25 20:44 GMT+0000
My pc :)
https://linustechtips.com/topic/335179-first-build/#findComment-4571596
Do not play games such as War Thunder and World of tanks on an AMD processor. They dont work so well with those games.
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
https://linustechtips.com/topic/335179-first-build/#findComment-4571696
