NZXT S340 3 front fans?
Solved by c3p0_,
Spacewise you could barely fit an thin 360 in the front. I tried to hold 3 120 against it and there is space. But needs a lot to cut out. Thin 280 fits no problem. Wider 280 after removing the cableshroud.
Thing is there needs to be a cut in the psu shroud and remove the entire hdd cage which is bolted. I dunno if this would leave the case stable when cutting at this points.
Featured Topics
Silencix ·
Posted in Cases and Mods1 -
3
LambdaBird ·
Posted in General Discussion3 -
1
10
3
2
joe_ollie909 ·
Posted in CPUs, Motherboards, and Memory8 -
DreamCat04 ·
Posted in PC Gaming1 -
saltycaramel ·
Posted in Tech News3
