Upgrading my pc need some help
Go to solution Solved by stconquest,
Use the cooler from the celeron:
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core OEM/Tray Processor  ($229.95 @ SuperBiiz)  This is like a locked i7,  It has hyperthreading.  It will game just as well as the i5 or i7, clock for clock.
Memory: Crucial Ballistix Sport 4GB (1 x 4GB) DDR3-1600 Memory  ($29.23 @ Amazon)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($79.99 @ Newegg)
Total: $339.17
Generated by PCPartPicker 2015-03-26 08:35 EDT-0400
heey guys,
I have a very important question. i want to upgrade my pc, my budget is 350$ (USD). What i want with my upgrade is a good workstation or the best i can get with this budget.
My pc specs :
CPU : Intel Celeron g1820 with stock cooler
Graf Card : Nvidia Geforce 520
Motherboard : MSI H81m P33
4GB Ram
If you have some suggestions leave them down below.
Thanks!
https://linustechtips.com/topic/334939-upgrading-my-pc-need-some-help/
I'd say the CPU first, then the GPU / RAM.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
There isn't much you can really do besides upgrade the memory and or GPU. Your motherboard only supports Celeron and Pentium processors so in order to upgrade your CPU, you will also need a new motherboard.
Dude no. The msi h81 p33 is a socket 1150 motherboard. It supports any processor of said socket (after a bios update).
I would upgrade the proccessor and the mother board
<THE SILENT ASSASSIN>CPU(Intel i5-4690K)||COOLER(corsair H100i)||MOB(asus Maximus VII Hero ATX)||RAM(16gb of corsair vengeance)||STORAGE(Intel 530 128gb)(Samsung 850 Pro 500gb)(WD 2tb Black)||GRAPHICS(2 x Asus strix 970)||CASE(Nzxt H440)||PSU(Corsair RM750W)>http://pcpartpicker.com/b/Bbpbt6
it also supports i5 it is a 1150 so it supports more than that ;)
CPU: E3-1231v3 (update BIOS prior to install) ~$256 USD
When you say workstation it would depend on exactly what work you're doing for either GPU or RAM upgrade. You'll need both eventually, rendering/editing work that doesn't require a lot of RAM, but could use a GPU upgrade, find a used GTX 770 (CUDA Accel. -depending on software). If you don't need CUDA, a used 280X assuming you have a PSU that can power it.
If you don't need hardware level acceleration, any 8GB RAM kit will do, may be able to expand on the kit you currently have. I can't find a single 16GB kit listed on MSI's compatibility page, not sure if the board supports 16GB or higher.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
heey guys,
My pc specs :
4GB Ram
Thanks!
Put an i5-4440 in there and get either a r9 270 or 270x, if I were you I'd stretch the budget a bit and get an i5 4440 and a r9 280
For the GPU, I think NVIDIA would be better because CUDA helps more in video editing.
PC Specs
Indonesia
Australia
Yeah I saw this on the MSI website and I guess I missed the "Core" part lel...
Total: $339.17
