heey guys,
I have a very important question. i want to upgrade my pc, my budget is 350$. What i want with my upgrade is a good workstation or the best i can get with this budget.
My pc specs :
Intel Celeron g1820 with stock cooler
Nvidia Geforce 520
MSI H81m P33
4GB Ram
If you have some suggestions leave them down below.
Thanks!
https://linustechtips.com/topic/334844-help/
heey guys,
My pc specs :
Nvidia Geforce 520
MSI H81m P33
4GB Ram
Thanks!
You could pick up a locked i5 4460 or similar, that would be a huge boost right there. Couple it with another 4Gb of RAM and you're golden for a workstation. Depending on where you live that should come in well under $350.
You'll probably need to do a quick BIOS update to support the newer Haswell refresh chips.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/334844-help/#findComment-4566337
