okay probably not a real electrician just a guy who knows more about tools than me,
I got these RGB LED's from amazon http://www.amazon.com/gp/product/B006K0JYD8/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
I'd like to hook them to my power supply instead of running them of the case and plug them separately, i know it can be done but i don't know how :P Help?
PSU is AX1200i
https://linustechtips.com/topic/334758-electricians-help/
as far as i can see the adapter that included with the leds is a 110V to 12V DC convertor.
So basicly, you should be able to just cut off that whole convertor, and solder a molex plug with yellow and and black wire to the white control unit. Yellow is +12V black is Ground.
Just make sure you know which wire of the leds is plus and which is minus.
And then connect those that control unit directly to the psu due molex connection.
https://linustechtips.com/topic/334758-electricians-help/#findComment-4563923
PSU is AX1200i
You'll need one one of theses just make sure it's pinned for 12V operation:
T1Lji3FitgXXXXXXXX_!!0-item_pic__45651_z
https://linustechtips.com/topic/334758-electricians-help/#findComment-4563930
you can strip the wires, connect the yellow (12V) and ground (black) to a molex in the pc.
edit: i apologize because the first guy to respond has a close answer to me.
i7 4930k / Asus GTX titan / 16 gig dominator platinum / asus rampage extreme IV black edition AC4 / RM850 PSU / 512 samsung 840 pro
https://linustechtips.com/topic/334758-electricians-help/#findComment-4576554
You can get a bunch of molex to sata adapters and cut the sata end off, then solder the open ends to the terminals on the strips.
You can make three or six led segments and stick them in the crevices of your case to hide them.
Dammit now I want to do this.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/334758-electricians-help/#findComment-4581020
For RGB LED strips it needs to go into a controller first but for single color LED's that is the easiest way to power them by directly soldering on a 12V power source.
If your interested they are fairly cheap for just an entire roll.
SMD 5050:
http://www.amazon.com/SUPERNIGHT-TM-Waterproof-Flexible-Lighting/dp/B00DTOAVYY/ref=pd_sim_hi_10?ie=UTF8&refRID=0KN2GCEAMHSVNJXDKTVM
SMD 3258:
http://www.amazon.com/dp/B00JRT4BYQ?psc=1
https://linustechtips.com/topic/334758-electricians-help/#findComment-4581205
SMD 5050:
SMD 3258:
I wish you hadn't linked those. Now I need to buy them.
https://linustechtips.com/topic/334758-electricians-help/#findComment-4583005
