first do a full scan with the kaspersky av tool
and malwarebytes and probably superantispyware
you can use the hp usb format tool to format the usb if thats what you wanna do...
http://www.kaspersky.com/antivirus-removal-tool?form=1
http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
HP format tool says it write protected. I will try another AV tonight, at school now.
Link to liver Linux? And what does it do, will I be able to run a Linux distro from a USB without installing it?
Yup
Just search in Google "Ubuntu download", it will bring the Ubuntu homepage.
Then download tool called UNetBootin it's easy to use, you will choose the .iso of the Ubuntu from your disk and browse on what USB you want to "install it to" . (UNetBootin has builtin Linux downloader as well, so you can just choose which Linux you want and destination USB and it will download and do a boot USB from it).
And last, boot from USB and choose something like "try Ubuntu without instalation" or "something something live" . Depends on distro.
And there should be gparted built in it. If it's not, just open terminal (search in programs for terminal - which is console) and run this command "sudo apt-get install gparted"
.. 3 seconds after this command you should type "y" as it ask you if you really want to install it.
After that type to terminal "gparted" and hit enter Or find the gparted icon and double click.
(if you run gparted (or any program) from terminal window, you must not close that terminal session . It will close the whole application. ) sorry for typo's, I am typing this on freaking tablet.
As the others have suggested, Gparted is your best shot at sorting that out.
EaseUS Partition Master might also be able to do it under Windows, but if you suspect that it's virus-related you may want to sort it out under Linux.
try booting a linux live cd and reformat it from linux...
Yup
gParted didn't work, it says drive is write protected,
I don't know if it'll help but you could try using DD, typing something along the lines of "sudo dd if=/dev/zero of=/dev/XXX" replacing the XXX with the usb stick, you can use "sudo fdisk -l" to find the usb stick, It'll be something like "/dev/sdb"
http://i.imgur.com/Mi8fOf5.png<--- Example
2500K @ 4.5GHz | ASRock P67 Extreme 6 | 16GB Ram | GTX 750 Ti | 250gb SSD | 1TB+2TB HDD | 720W CoolerMaster PSU | Essense STX Sound Card | Define R5
HDD LLF - http://hddguru.com/software/HDD-LLF-Low-Level-Format-Tool/
If you can't format it normally (and by the way if Windows says it write protected so will Gparted) then give it a Low Level Format. Its fixed a few USB drives for me in the past.
Main Rig:-
Server:-
Ok, command line it is then ...
I don't know your technical skills, so I'll try to keep it as simple as possible. I'll use capital letters for the bits you need to type and regular ones for everything else.
In windows, open an elevated command prompt (type "CMD" in the start menu, right-click cmd.exe and select "run as administrator")
Once the command prompt appears, type DISKPART and hit enter. Wait for Diskpart to start up.
Type LIST DISK and enter. Find the usb stick in the list and make a mental note of the disk number (0, 1, 2, 3 etc).
Be careful here, remembering or entering the wrong number might have catastrophic results.
Type SELECT DISK # (where # is replaced with the disk number that the PC assigned to the stick) and enter.
Once it confirms that the stick is selected, type ATTRIBUTES DISK and enter.
You'll now get a lot of info on the stick. Look for the Current Read-only state. If that says "yes", type ATTRIBUTES DISK CLEAR READONLY and hit enter again.
If that doesn't do the trick or if the Read-only state says "no", I'm out of ideas.
Okay, did it and the results; when I do ATTRIBUTES DISK CLEAR READONLY I get an answer in CMD saying Disk attributes cleared succesfully  but my flash drive remains read only.  Heh, :|
The software you linked does not work. It shows plenty of "The media is write protected errors"
If a low level format failed i'm afraid its fubar, chuck it in the bin and get yourself another.
Main Rig:-
Server:-
is it possible the permissions are just set wrong..? see if you can take ownership. may not work, but its worth a shot.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
No chance, a low level format wouldn't care about ownership, it unmounts the drive before it formats it anyway so technically its not owned by anyone.
I've heard theories that a certain type of failure can cause flash rom to get stuck in its write mode and because it thinks its still writing data it shows as write protected, not sure if that's true or not though. Its a very common issue with flash drives, just google write protected flash drive and check out the amount of hits.
Main Rig:-
Server:-
Yeah. I think it's because I may have ran a game form my stick.
I guess an RMA was the right idea.  If a low-level format, gparted and diskpart failed to fix it, I don't see what would.
Running a game from the stick shouldn't be a problem.  I used to have GTA:SA on a USB stick and never had a problem with it.
