Small issues with overclocking pentium g3258
Solved by Hman1250,
That's the reason why, the fan is the component in the CPU cooler to keep it cool at stock and overclocking. IMO, try to return the cooler and get something smaller like a Hyper 212 from cooler master, your RAM can fit and is an inexpensive cooler and get around the same clock speed. My friend has a 4770k and uses a hyper 212 evo and runs at at 4.2GHz around mid 50's under load.
As well what motherboard are you using to OC your CPU
