Where can I get a reference cooler?
sina
So, long story short: I ended up buying an EVGA ACX 980 last year when the reference cards were out of stock across the board. I kinda regret my decision though, because the reference 980 just looks so much sexier. Also, the blower design might actually perform better since my case fans would be pointing directly at the intake.
I guess my question is this: is there any way I can obtain the cooler by itself now? I looked on eBay and found nothing, which is rather unfortunate.
School machine: 2012 MacBook Pro, i7-3720QM, 16GB 1600Mhz DDR3, 256GB SSD, GeForce GT 650M
Gaming machine: Asus X99 Deluxe, i7-5820K, H100i, 16GB 2666Mhz DDR4, 256GB 850 Pro, 2x WD10EZEX, GeForce GTX 980, AX860
I don't think that it would even fit.
The card I have is completely a reference design, just the coolers have been swapped for a custom one (if I'm not mistaking). Most of the early 980s were like this.
Contact Digital Storm, EVGA or even NVIDIA themselves for a stock GTX 980 cooler. They should sell you one.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
eBay would've been your best bet
believe the 970 has the same reference cooler, so if you found a 970 cooler you might be able to slap it on
Honestly though your going to have a tough time
Try putting a wanted ad in the classifieds?
http://linustechtips.com/main/classifieds/
Also correct, I didn't even think about that
But it might be a tad expensive
It may be, though IIRC it should be about $50.
EVGA wasn't of any help (I mean after all, the ACX is their flagship cooler).
I'll try Digital Storm and NVIDIA, but I have to ask first: why Digital Storm of all companies?
I know that they take the coolers off of the cards to watercool them, and in the past I have remembered Nav (@digitalnav) saying to me that they sold them.
Fair enough. I'll give them a call soon to ask. If that proves futile...@digitalnav pls.
was having a little google and found this:
40340_05_nvidia_geforce_gtx_980_referenc
man why dont nvidia do this out the box!!
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
