Wired vs. Wireless for game ping?
Solved by Gugos,
no you will not reduce your ping of a noticeable amount, it mostly concern where you are and where the server you're connected is, but you'll have a more stable connection for sure, because everytime a packet get lost (and via wi fi it happen quite often) the TCP halve the packets that can be sent, and this situation is really rare in a wired solution.
In conclusion: go wired!
