Need help choosing an entry level gaming GPU
All you will need is a GTX 960 (4GB more preferably) to play almost all games today at 1080p with good graphics. It will be able to run three displays but not game on all three, if you are thinking about gaming like that you may just get a GTX 970. Cheers!!!
Disagreed, looking at Nvidia Surrounds site it says that the max resulotion on a single GPU is 10240x1600 (When running 3 1080 monitors you have 5760*1080). Agreed that max graphics is not always possible, but Surround pickers can't be choosy.
@Stijncat I would like a silent GPU overall
@dadasmithywinkle the site says it supports the latest AMD R9 2xx series and the Nvidia GTX 7xx series but do I have to get that specific series GPU? Well, I guess if I want to use 3 monitors then the answer is yes, right?
You can get that series, or any newer ones. GTX 700 and up support surround, R9 200 and up support whatever AMD calls it.
If you want silence, check out ASUS and MSI, they tend to build on 0db passive modes, for when its not under load.
EDIT: fixed number resolution, and underlined it.
