Is that crown value calculated from the 550USD?
https://linustechtips.com/topic/332979-itx-build/#findComment-4518629
I'd swap that GTX960 for an R9 285 if you intend to keep using that case, it's usually cheaper and is a bit better :)
http://pcpartpicker.com/part/powercolor-video-card-axr92852gbd5tdhe
Or if you want to step up to the Elite 130 you can get an R9 280 or 280X for a similar price to the 960 which will destroy it.
And before someone says "amd cards are too hot for itx"...
They aren't. I run one just fine.
https://linustechtips.com/topic/332979-itx-build/#findComment-4518635
I am gona build a PC for my sister is this a good build? http://pcpartpicker.com/p/m2fPNGIt cost about 559 US$ in swedish crowns it cost 6.600kr that it's much.
id go for something like this
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($114.95 @ SuperBiiz)
Motherboard: MSI H81I Mini ITX LGA1150 Motherboard  ($59.99 @ NCIX US)
Video Card: HIS Radeon R9 285 2GB Mini IceQ X² Video Card  ($189.99 @ Newegg)
Case: Thermaltake Core V1 Mini ITX Tower Case  ($34.99 @ Newegg)
Total: $558.99
Generated by PCPartPicker 2015-03-22 14:36 EDT-0400
AAAAAAAAAGGGGGGGHHHHH!!!!
https://linustechtips.com/topic/332979-itx-build/#findComment-4518715
