I need a graphics card that can run somthing like BF4, H1Z1 and CSGO in 1080p. Im from England and my max budget for the graphics card is about £180 i was looking at an r9 280x but im really not sure im pretty new to pc gaming so i dont know whats best for my money any tips are appreciated
https://linustechtips.com/topic/332851-need-help-choosing-a-graphics-card/
I would be going for the R9 280x in your situation. The prices of 4gb GTX 960 cards are all above your budget. You could still purchase a 2gb card, but this decision may hamper you in the near future. The 280x will have 3gb of memory which would be beneficial.
If you can find a 4gb GTX 960 then get that without delay.
I was using these website for comparison. If anyone has better links, maybe you could share them with the OP.
http://www.idealo.co.uk/mscat.html?q=r9+280x
http://www.idealo.co.uk/mscat.html?q=gtx+960
Yeah im gonna get a 650w PSU so its all good
then ya, the 280x is your best bet. do yourself a favour tho. do not cheap out on your power supply. spend the money and get a good quality one.
Edit:
I speak from experience. my first pc met an untimely end due to a cheap power supply.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
