thats to hot
you didn't mount it tight enough
if you can afford it yes...get a 212 evo
or something else if that one is too big for your case
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/332667-cpu-temps-are-high/#findComment-4514997
That's not bad on a stock cooler, could be better, but not in the danger zone (read that in archers voice)
Always nice to get a aftermarket cooler for better temps though.
75-80 is a ways off from hurting your chip.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/332667-cpu-temps-are-high/#findComment-4515032
Should I buy an aftermarket cooler or will this be fine since i am not overclocking.
80C is bit on the hot side. But if its not up there or over it whole time you are doing something CPU heavy, then you are fine with stock cooler. You could check if you can improve airflow inside case. Like with better cable management or extra fans. Then again, buying cheap aftermarket cooler is almost as expensive as getting 2 new good fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/332667-cpu-temps-are-high/#findComment-4524083
when  you say under load...how long does it have to be under load to reach 80C
and how many fans in the case
the last i5 I installed with the stock cooler ran at like 38-43C on idle..and like up to 65-70C on load after like 30-45mins
https://linustechtips.com/topic/332667-cpu-temps-are-high/#findComment-4524097
